HELP: How do i edit the thickness of subregions.
5 ANTWORTEN 5
Nachricht 1 von 6
johnNVX5H
1519 Aufrufe, 5 Antworten
I am trying to show the thickness of my sub region (Cast in place concrete) in section but all i get is the Earth fill/hatch. Any tips on how to solve this?
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: johnNVX5H
This is a common issue with subregion. You either have to draw in Fill region or you create floor slab to mimic the sidewalk.
Nachricht 3 von 6
Toposurface does not have any thickness. You can isolate the subregion in a 3d view, export to DWG, link it back in and create a roof by face. Alternately, you can find a dynamo script that convert a topo or a subregion to a floor with edited subelements.
Nachricht 4 von 6
als Antwort auf: ToanDN
doesn't this get problematic when you have multiple subregions at varying thicknesses?
E.g Isolating Subregion will isolate 'all sub regions' therefore there would be a heck of a lot of tweaking in DWG fiels
Nachricht 5 von 6
fawzibaha
Check out this video, it looks like there is a solution to that!
https://www.youtube.com/watch?v=mM3-gj2f-gQ
Best
Nachricht 6 von 6
Corsten.Au
Hi
You may have to workaround and use the filters to keep it consistent and just one time setting.
Include these kind of filters in View template if required.
1. Topography
2. Sub-region
3. Customise " Comments" for subregion
4. Use comments in Filters to identify variation such as Concrete, Landscape etc.
5. use filter to control the graphics for section... ( or plans as well ).
Cheers.
Filters using " comments" of Subregion.Filters using " comments" of Subregion.
Corsten
Building Designer
