Hi guys,
I have my project with brick walls.
I have tried everything i can to be able to see all brick patterns/image on all walls and no luck. Some show no brick just some color while others show the brick.
Could anyone please tell me how to solve this urgently? ![]()
Picture attached.
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
Are you sure the walls are facing the right directions (brick out, vs toward the interior)
Howard Munsell
Are the Brick Walls all using the same Material or different? If different, check the Material's Appearance tab settings. That's what determines the Realistic Appearance.
or , maybe you have walls in different Phases (Existing for first Floor and New for second Floor)and Phasing Filter to Show All...
Constantin Stroescu
THANK YOU ALL FOR YOUR RESPONSES!!!!! ![]()
I FOUND THE LITTLE TRICK (IM A NEWBIE TO REVIT) AND FIGURED I CAN FLIP THE WALL BY PRESSING THE SPACE BAR! AND IT DID THE TRICK!!!!
This was def the issue lol but instead of the clicking on the flip arrows I pressed space bar and it did the trick! Thank you ![]()
