Does anyone have any idea why mechanical equipment copy/monitored from a linked file would not be adhering to the set object style? Trying to override the graphics in view by the mechanical equipment category doesn't seem to work either. The only way I can seem to change the graphic display of these elements is to override by element, which is pretty tedious.
There is no phasing override, no view template applied, no filters or worksets being used.
I'm out of ideas
Gelöst! Gehe zur Lösung
Gelöst von zwebber24. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Are there any nested families in the mechanical equipment family? If yes and they are under a different category + shared then they show using their category's object styles.
