Help! Creating a staggered stud wall assembly
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
emilys27ZKX
394 Aufrufe, 2 Antworten
I am trying to create a staggered stud wall assembly similar to attached picture.
I cannot figure out a way to create this condition from the edit assembly menu. I also haven't been able to find any resources online. Has anyone else found a work-around or solution to show staggering studs? Open to suggestions!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: emilys27ZKX
Create a wall type assembly with a 5 1/2" wood core, name and description properly to say what it is with the required STC value.  The staggered studs should be taken care of by a detail or a wall legend.
Nachricht 3 von 3
emilys27ZKX
Makes sense, thank you!
