Hi there,
I used to use hatch22 but my company has since gotten rid of it. Can anyone help me create a 6"x48" running bond .pat file?
THANK you!
Gelöst! Gehe zur Lösung
Gelöst von hugha. Gehe zur Lösung
Gelöst von Pattycake_Kyle. Gehe zur Lösung
Gelöst von Jason_S. Gehe zur Lösung
Download and install PyRevit. (free--search online)
It has a similar Hatch Pattern Creation Tool.
You draw lines, select them, and it creates the .pat file.
Then assign the custom pattern to your model/material.
@Anonymous wrote:Hi there,
THANK you!
See attached. I had to zip it because the PAT file would attach.
PAT file for download: 48" x 6" Running Bond 50% Offset
No add-ins to figure out or anything to install. And currently the largest library of free .PAT files you can find.
Our PRO accounts have access to template where you can iterate countless number of settings for custom PAT files. (where this is created from - GIF of that below). Cheers! :geburtstagskuchen:
6x48 with 50% offset
This pattern contains two elements: one unbroken horizontal and one broken vertical.
; Written by HatchKit 4 Professional Edition
; HatchKit 4 Professional Edition (c)1990-2020 Cadro Pty Ltd
; www.hatchkit.com.au/
;%VERSION=3.0
;%UNITS=INCH
*48x6 Running Bond
;%TYPE=MODEL
0,0,0,0,6
90,0,0,-6,24,6,-6
hth,
Hugh Adamson
