The trick of copy/monitoring from a linked model to convert from roof-based to face-based is not working. Revit keeps crashing!
Have tried changing the category of this family to each of the elegible categories for copy/monitoring but Revit keeps crashing for every single attempt.
Can anyone help, please?
Thanks in advance.
J
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
CTRL C>> CTRL V the geometry into a face based template
You will need to re constrain, parameterize, everything.
My understanding is that you need to create an equivalent face based family, load it to your project, and choose it as the substitution when you copy/monitor the roof based elements from the link in.
I just tried your family, change the category to Mechanical Equipment, and the copy monitor trick worked. After that I made it to Window again. You need to fix the original before you do it because on of the curve glass is flying off the frame. And fix the void so it will cut properly.
