Help converting 3d dwg to revit family
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
968 Aufrufe, 6 Antworten
Can someone please help me convert a washer and dryer from a 3d obj/3d dwg to revit families please? When I try to import or link, it stalls at 40% every time and stops responding. I'm using Revit LT and don't have any other programs to mediate.
https://www.askona.com/dryer/t411vdw
https://www.askona.com/washer/w4114cw
(These are the T411VDW and W4114CW downloads from Asko, I reached the max trying to link both zip files.)
Thanks!
6 ANTWORTEN 6
Nachricht 2 von 7
PavelAnd
als Antwort auf: Anonymous
There in no Revit nearby now. May be you can install a trial version of Revit2020 and try to import? It may be faster...
Best regards, Pavel Plotitsyn.
Nachricht 3 von 7
What "3Dobj" or "3d dwg" are you  referring to? There's none available at the Links you provided.
Nachricht 4 von 7
als Antwort auf: barthbradley
At the bottom of the each page there is a download link called "3D Drawings" which downloads the zip folder. I couldn't attach the zip in my original post because they are too large.
Nachricht 5 von 7
The drawing was converted from a very detailed 3d model with all the nuts and bolts and dust and whatnots.  On top of that it was converted to meshes or poly surfaces instead of ACIS Solids.
I wouldn't import a 45MB drawing of a washer to a Revit family.  Even if you can, it will bring Revit to its knee when you load the washer in your project.  There are plenty of W/D Revit models from other manufacturers or even generic that is much more smaller/cleaner and even packed with useful parameters.
Nachricht 6 von 7
Attached TD85-Logic-V-XL-W-3d
Nachricht 7 von 7
WM85-Logic-XL-W-3d.rfa  Attached
