Help - Can't connect Overlapping walls
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1142 Aufrufe, 8 Antworten
Please help.
I have a straight wall and a curved wall. I want them to combine into one wall and not look overlapped as shown in photo.
Please help me find a solution.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Join Geometry (Modify Tab)
Nachricht 3 von 9
dominik.malec
als Antwort auf: barthbradley
Hello, @Anonymous
If you want to have "the regular, straight wall" inside the room and "the curved wall" outside you need to define this part of wall by means of model in-place by extrusion. The in-place extruded wall should replace the part between red arrows on the screen shot below:
Dominik Malec
Nachricht 4 von 9
dferreira-blackwell
Nachricht 5 von 9
Corsten.Au
Join Geometry and switching join orders.. Walls and Columns..Join Geometry and switching join orders.. Walls and Columns..
Corsten
Building Designer
Nachricht 6 von 9
als Antwort auf: Corsten.Au
THANK YOU ALL!
Nachricht 7 von 9
Wow! How exciting! I was right!  In the very first post I said "Join Geometry (Modify Tab)"!  Yippee!
...Booyah, @Corsten.AuSmiley (zwinkernd)
Nachricht 8 von 9
Corsten.Au
Hi. Even @barthbradley mentioned joined geometry as a solution . You can go ahead accept that as a solution as well.
Not just explain why didn’t that helped you if you don’t mind.
cheers !
Corsten
Building Designer
Nachricht 9 von 9
...however, yours was much better than mine, @Corsten.Au.  Well illustrated, as usual.
Cheers
