help buffering wheel
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
tomZRS63
993 Aufrufe, 6 Antworten
when I click on the help button, in revit, it goes to the site but a buffering wheel in the center goes around and around forever.
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: tomZRS63
it could be your internet connection? or you can try this and see if helps. thanks
1)Open the Control Panel. Click on Programs (if you use View by: Category) and then Default Programs or Default Programs (if you use View by: Small icons or Large icons)
2)Then select “Associate a file type or protocol with a program”.
3)Scroll-down and choose the .html element and click on Change program (top right-hand)
4)Choose one of your internet browsers (Example: Firefox, Google Chrome, Internet Explorer, Opera, etc…)
5)Try to search for something in Revit again.
Nachricht 3 von 7
fatal.error
If the "buffering wheel" keeps running inside your Revit window, the system firewall could be blocking Revit's internet access.
If the "buffering wheel" keeps running on your web browser, could be due to an Autodesk's server temporal issue, a browser extension that is avoiding content loading, lack local internet access, etc.
Meanwhile, you can find Revit Help Documentation on the following links:
Revit 2018 Help: https://help.autodesk.com/view/RVT/2018/ENU/
Revit 2019 Help: https://help.autodesk.com/view/RVT/2019/ENU/
Revit 2020 Help: https://help.autodesk.com/view/RVT/2020/ENU/
Revit 2021 Help: https://help.autodesk.com/view/RVT/2021/ENU/
Nachricht 4 von 7
Stand up and step away from the computer very, very slowly. Keep your hands at your side and don't make any sudden movements.  When you are at a safe distance - outside of the blast zone -- call 911.
We're rooting for you.
Nachricht 5 von 7
tomZRS63
als Antwort auf: barthbradley
step away from that controlled substance.
You can do it.
Nachricht 6 von 7
You can do it.
Hydroxychloroquine
:zwinkerndes_Gesicht:
Nachricht 7 von 7
tomZRS63
als Antwort auf: ennujozlagam
I didn't have the exact options you mentioned, but I did a reset as one of the options and this fixed it.
Thanks, have a great day!
