Height parameter not stretching whole family
3 ANTWORTEN 3
Nachricht 1 von 4
sshamby
654 Aufrufe, 3 Antworten
So I have created a simple family with a width and height instance parameter. It has a total of 5 extrusions. When i apply the width parameter to the model everything moves as its suppose to. But when i apply the height parameter it causes the top extrusion to move independently from the rest of the extrusions. I have locked the extrusions to the reference plane and locked the extrusions to each other but its still moving like this. Can anyone identify what I am doing wrong?
I have attached some screenshot to help better explain the problem
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: sshamby
Add more reference planes/lines and use more constraints to fix the extrusions.
Consider uploading your family if you need more detailed advise.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
Karol_Piroska
seems like the sides are only locked to side and btm ref planes , top corners/ends are not locked to the top reference plane. Otherwise you would get a warning
Nachricht 4 von 4
...we might have some other suggestions for you, if you want to post the family for us to look at.
