Height dimensions problem
5 ANTWORTEN 5
Nachricht 1 von 6
PIADA_JanM
468 Aufrufe, 5 Antworten
i'm having some problem with height dimensions (for the first time) and I have no idea what's wrong.
As you can see in the picture, dimension 2+3 are fineheigh dimensions.PNG, n.1 is acting weird.
Dimension 2 is there for foundation under wall, it is showing both top and bottom height.
Dimension 3 is there for wall, showing both top and bottom height.
Dimension 1 is there for foundation under wall, but showing only top heigh, bottom is weird highlighted on the right.
If I try to make any foundation under -1,000 it starts to show this number. Any other construction work fine. In sections dimensions work fine too.
What is wrong with my foundations / model ?
5 ANTWORTEN 5
Nachricht 2 von 6
cbcarch
als Antwort auf: PIADA_JanM
It looks like #1 is attached to a vertical surface, 2 & 3 are attached to a horizontal surface.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 6
PIADA_JanM
als Antwort auf: cbcarch
No, they are all to horizontal. Not to mention, it really doesn't matter where I attach them. If I make foundation n.2 only 1 mm deeper (-1.001), dimension value turn to that infinity number too.
Nachricht 4 von 6
elzohry2007
can you uplaod the revit file ?
to see where is the problem
Nachricht 5 von 6
PIADA_JanM
als Antwort auf: elzohry2007
Here is the cleaned file.
Also, it's structural plan and I'm looking up. If I move the view range below foundations, those wrong height dimensions got their normal value.
If I add new dimensions and move the view range up, to cut through foundations, the new ones are displayed correctly, old are back the weird value.
Nachricht 6 von 6
elzohry2007
Just copy the spot Elevation and move it to the correct position (using Ctrl + move mouse )
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Hosam Elzohry , ACI , ACP, Autodesk Ambassador Gold
BIM Manager
https://www.youracclaim.com/users/hosam-elzohry/badges
