I'm working on a project to convert architectural Revit model to dgn format using i-model plug in from Bentley.
I cannot select the analytical model as it gives me an error.
If I try to do the process by unselecting analytical model, it gives me the below error.
"Message: Failed to set material: Mapping for Revit type does not exist"
This errors stops the import of Revit floors and walls to dgn format and my exporting is stuck every time.
Any help would be greatly appreciated! Thanks
Rahul
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
What version of Revit are you using?
Have you created an Analytical Model in Revit as architectural models do not usually include this element?
Are the Walls and Floors classed as Structural in the model as they probably wont be recognised by the addin?
You could also try a generic Export to DGN - File > Export > CAD Formats > DGN
Thanks Jay.
I'm using Revit 2021. I will definitely take a look at your suggestions and get back to you.
I also tried a generic export and it does not work while importing back to open buildings 2023.
One good point here is that Revit automatically creates an analytical model if the elements are Structural where as in later Version 2023-2024 it is not.
Have you tried contacting Bentley?
Thanks.
I checked this page. I cant seem to find such an option under add-ins.
