having trouble filtering sheet list, phases and shared sheets
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
David125
1368 Aufrufe, 6 Antworten
I have a project that has 2 phases, some sheets are phase specific others (like detail sheets) are used in both phases. I can make a sheet list and filter it so I see my phase 1 and shared sheets but when it comes to filtering to show phase 2 and shared sheets I can't get it to work. I have a paramater called PHASE. I've numbered shared sheets "0", phase 1 sheet "1" and phase 2 sheets "2".
The filter I use for the phase 2 sheets is - Filter by: PHASE "IS LESS THAN OR EQUAL TO"  "2".
For my phase 3 sheet list I used - Filter by: "PHASE" "EQUALS" "3", and PHASE "EQUALS" "0", this phase 3 filter I did gave me a big goose egg.
6 ANTWORTEN 6
Nachricht 2 von 7
David125
als Antwort auf: David125
For those of you that are sticklers about "typos", this is a correction.
Phase 1 filter - Filter by: "PHASE" "IS LESS THAN OR EQUAL TO"  "1".
Phase 2 filter - Filter by: "PHASE" "EQUALS" "2", and "PHASE "EQUALS" "1"
For the phase 2 filter I am using the PHASE parameter twice, is there a Revit law against that?
Nachricht 3 von 7
PHASES: 1, 2, 1 and 2
Phase 1 Sheets: PHASE contains 1
Phase 2 Sheets: PHASE contains 2
Nachricht 4 von 7
David125
als Antwort auf: ToanDN
Please let me know if I'm not understanding you correctly. I'm trying to display 2 of 3 different types of sheets on a schedule.
I have a prameter called PHASE where,
0 = Shared sheets
1 = Phase 1 sheets
2 = Phase 2 sheets
"Phase 1 Sheets: PHASE contains 1" - Setting phase 1 sheets to "PHASE contains 1" will show only phase 1 sheets not shared sheets.
"Phase 2 Sheets: PHASE contains 2" - Setting phase 2 sheets to "PHASE contains 2" will show only phase 2 sheets not shared sheets.
Nachricht 5 von 7
You renumber shared sheets PHASE from [0] to [1 and 2] so that:
- Filter "contains 1" will show [1], [1 and 2] = all Phase 1 + shared sheets
- Filter "contains 2" will show [2], [1 and 2] = all Phase 2 + shared sheets
Nachricht 6 von 7
David125
Got it. Thanks. It works great now.
Nachricht 7 von 7
bstraubingerDD9NR
Good morning,
would you happen to know why this filter works on some but not all sheets? I have (2) sheets not showing up on the schedule they should, strange..... they have the filter number in their properties just like the others....
