Having trouble downloading .pat files from RevCity to Revit Lt
5 ANTWORTEN 5
Nachricht 1 von 6
tony.marsh72
534 Aufrufe, 5 Antworten
I am attempting to download .pat files from RevCity.  I have downloaded the .pat file and then go into Revit LT/manage/fill patterns and then "add new."  I can search for the file and then select it.  I get a message that states "No Drafting type patterns found."  Can someone please help me as I have tried this on two separate computers with two separate Revit downloads and get the same message.
Thank you.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: tony.marsh72
Maybe the pat files are for model patterns.
Nachricht 3 von 6
Mike.FORM
Open the .pat file and delete any and all lines which read     ;%TYPE=MODEL
Nachricht 4 von 6
tonyE93YG
It is the "gravel" pattern in RevCity.  I've tried other .pat files and I am getting the same message.
Nachricht 5 von 6
Mike.FORM
share the .pat file, maybe it is missing a comma or some other syntax somewhere.
Nachricht 6 von 6
tonyE93YG
als Antwort auf: Mike.FORM
Sorry it took so long but I appreciate your help.  I have downloaded the file...thank you so much for your help!
