Hello!, how do you vary the type of hatch, automatically, according to the degree of detail? (for walls for example, material based)
There are two kinds of hatch - Drafting and Model.
Drafting hatches are very small scaled and are good for details. They will adjust per the scale of the detail. Most components - walls, etc - will come in with their own material hatches.
Model hatches are full scale and are meant to be applied to the model.
Anything specific that you are trying to achieve?
Hi Rsaray, i post on picture to help explain,is possible to auto change to another kind of hatch, when i change of high to low detail? actually when pass to low detail the hatch just dissapers.
Also - when you switch from High to Medium to Coarse level of detail, Revit will hide hatches.
Where did the hatch come from? Is it from the wall style or is it a filter that has been applied on the walls?
Can you share the file?
