Will Revit read multiple custom fill patterns from the same .pat file (similar to how it reads multiple Shared Parameters from the same text file), or do I need to create a separate .pat file for each custom fill pattern?
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
Yes. if you have one .pat file with multiple patterns in it, you can use it to add patterns in reivt.
tht said, the .pat file needs to be set up properly. you CAN NOT use the autocad .pat file with revit without modifications. drafting patterns need to be identified as Drafting and model patterns need to be identified as Model.
attached is a sample .PAT
Howard Munsell
Hmm. I must have forgotten a required character in the text file. Now it's loading the multiple patterns as I thought it is supposed to do. Thanks for your response.
