HATCH PATTERN
3 ANTWORTEN 3
Nachricht 1 von 4
markkibui101
632 Aufrufe, 3 Antworten
HATCH PATTERN
Hi, Mark here.
My question involves having an insulation hatch pattern in a roof section without having to draw it manually every time a section cuts through the roof. I have managed to load in a PAT file but the challenge is sizing the hatch to fit the 145mm width required. The hatch is either to big or too small. Also it does not follow the inclination of the roof.Help
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
martijn_pater
als Antwort auf: markkibui101
You would use insulation tool manually in the view, cut patterns are drafting patterns so it is not possible to do it directly as you'd like. Could just use a crosshatch though i.e.
Nachricht 3 von 4
markkibui101
als Antwort auf: martijn_pater
Okay, thanks
Nachricht 4 von 4
martijn_pater
