HATCH PATTERN
HATCH PATTERN
markkibui101
HATCH PATTERN
markkibui101
Hi, Mark here.
My question involves having an insulation hatch pattern in a roof section without having to draw it manually every time a section cuts through the roof. I have managed to load in a PAT file but the challenge is sizing the hatch to fit the 145mm width required. The hatch is either to big or too small. Also it does not follow the inclination of the roof.Help
martijn_pater
You would use insulation tool manually in the view, cut patterns are drafting patterns so it is not possible to do it directly as you'd like. Could just use a crosshatch though i.e.
markkibui101
Okay, thanks
martijn_pater
