Hatch pattern are too light.
Here you can see that the floor,brick and earth pattern are too light.How to make them darker.
Pierce_Fierce
Make sure that your Graphics Parameters are all set correctly (Properties>Edit Type>Graphics>Foreground Pattern Color/Line Weight etc.)  If your hatch patterns has a Line Weight Parameter, you can alter that, or what I normally do is change the Foreground Pattern Color from some shade of Grey to Black.  Don't forget, if you don't want the Hatch Pattern to change Project-Wide, duplicate the pattern to create a variation.
Hope this helps.
Check what your lineweight is for Pen #1 for the scale of your view.
Keep in mind...Pen #1 controls pattern weights and Pen #2 controls ceiling patterns.  Which is why many start their lineweights at Pen #3.
Do you mean on screen or print-out?  The shadow is on so you are printing in raster, the reason for the fainted image.  Adjust your printer raster quality / resolution and try different raster quality under Revit printing dialog (Presentation, Medium, etc...)
What is this "pen 1" and how to assign pen to hatch ?
