Hello! I was looking for a way to override wall hachs to accomplish some needs, but i cant find it. This is my problem: any wall in my project can have 5 different cut patterns, defined by phase and a condition (if it was builded with or without permission)
If its existing and permitted, i want to fill it sith solid black;
If its in any phase of construction , its filled it with solid red;
If existing but not permitted, its filled with a net pattern;
If not existing and not permitted, its filled with a line pattern;
and if its going to be demolished, its filled with solid yellow.
So i have a minimum of three phases (overriding hatch display for walls in existing and demolish phases, so the rest of phases and possible new ones stays OK) and im thinking about creating a yes/no parameter and apply it to "walls", but i dont know how to continue from that...
My idea is to have only one type of wall and change the phase and condition to change how it displays, and avoid duplicating walls just to change their patterns (i was doing that). Is there a easy way to do that? Or anyone can point me in the right way?
I started in revit this week so there will be a lot of things im missing.
Thanks!
