Hatch of a filled region appears halftone
frcfixo64
frcfixo64
Hello everybody.
I have a problem regarding a filled region.
It is created in a publication model with a linked geometry model and a linked topography model.
The hatch displays and plots in a lighter colour than it is setup to be (should be like the darker colour the template displays).
I have checked VV, templates, phases and other overrides but filters, as I am using an LT Revit version.
Thank you for your attention and help.
Replies (10)
vitorbortoncello
Possibly it is the link VG or filters, you should change the style to "by host" but Revit LT won't' allow to change it, only Revit full lets you customize links and create VG filters.
Check this too:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
frcfixo64
Hi Vitor.
Thank you for your answer.
All models have been done with LT licenses so I doubt we modified the link VG or filters.
Will try to check it out tho.
EDIT: Can confirm no filters are applied and RVT Link displays are as default. I attach some images.
azad.Nanva
this is for columns ,which pattern you use for the wall and the Structural Columns and Foundations element ?in this section we see walls and foundation element.
and you can check the materials of all.in links too.
by the way , you work for CIA hahaha
just kidding!
can you use the Filters?
frcfixo64
Hi Azad.
Thank you for your reply.
All sectioned elements of interest use the very same pattern through a template. It is the one shown in the image you posted.
It is also the same the hatch pattern uses.
I attach an image of the fill region/hatch pattern used. You can see it is the same.
What should I look for regarding the materials?
azad.Nanva
when you use the revit links, 2d item can not be showed in the view (in this situation),so if this is a link the 2d fill region is not showing in the view so you should use the filter and check the material pattern.material patern in the links file so you should open the link directly or use filter.
frcfixo64
Hi Azad and thank you once again for replying.
The filled region is created in the publication model. It is not retrieved from the link.
All operations regarding templates and visualization are done in the publication model, where I have two links (architecture & topography, where all the modeling is done).
azad.Nanva
Okay, now i can understand better.hide your links and see what happens with your Filled Region.
frcfixo64
Hi Azad. Thank you again for your time.
I have tried both hiding the links and unloading them but nothing seems to happen regarding the graphics.
I attach some images to compare.
frcfixo64
Hi again guys.
I have duplicated the files to upload them here so it may be easier for anyone willing to help.
I am still unable to find the error.
Thank you all once again for your help.
frcfixo64
Hi once again guys.
I think I was able to solve it.
The problem was related to the Filled Region "Line Weight" parameter.
It did not match the one stablished in the template for the cut elements.
Thank you to all the people who tried to help me.
