When I start Revit, I get this message "Graphics Options - Cannot Use Hardware Acceleration. Hardware Acceleration Disabled. Software Emulation mode is in use. "
I have 4 G graphics card / dedicated graphics gpu as well as 16 G RAM so I don't think this is accurate or should be happening. Any way to resolve?
Go to the Big R...click and then click on Options. Select Graphics...it will show you the warning issue about your video card.
You can also go into your Windows Device Manager and find out what card you are actually using. If it is an Intel Graphics Card you are going to be stuck with where you are at, as they are not supported.
"4 G graphics card" means... what, exactly?
Also, are you using a laptop? If so then management software may be auto-selecting the on-chip graphics hardware to save battery life. You'll need to adjust both graphics card settings to prefer the dedicated card (assuming you have one?) as well as system power settings.
Thank you. I have gone to the Options>Graphics section, and it acknowledges that the hardware acceleration is disable but it doesn't let me change it. I should have mentioned in my original post that I have a Macbook Pro 2016, and run Parallels on it. It's not an Intel graphics card, but I believe its the Radeon Pro 450 or 455. Any thoughts on why I still can't resolve? Or tips?
Thanks!
How would you have hardware acceleration when you are running under an virtualized environment? If you really need it, run Revit in bootcamp.
