Hanging lights on a sloped ceiling
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
vanderloo5
535 Aufrufe, 9 Antworten
I've posted this before but never really got a solution. What needs to be done with this light family to get it to hang plumb and at specific heights from a sloped ceiling?
Thank You
9 ANTWORTEN 9
Nachricht 2 von 10
RSomppi
als Antwort auf: vanderloo5
There is more than one way. I would opt for a level based family.
Nachricht 3 von 10
Mike.FORM
In the family you need to check always vertical.
And if you want to have the light be adjustable so it can be higher or lower you will need to dimension between the host ref plane in the family and another ref plane that has the geometry of the light associated to it and then an instance parameter associated to it.
Nachricht 4 von 10
vanderloo5
als Antwort auf: Mike.FORM
Thanks Mike But I'm not seeing an option, (always vertical), anywhere in the family properties.
Nachricht 5 von 10
Mike.FORM
in the family in any view. make sure nothing is selected and you should see these options in the properties.
Nachricht 6 von 10
vanderloo5
Not in my properties dialog?
Nachricht 7 von 10
blank...
Maybe it was created as a face based family, then had category changed to lighting.
The easy "solution" is to add a ceiling where you want it, use basic ceiling not compound, and host it on that ceiling. Then hide it.
Nachricht 8 von 10
Mike.FORM
The issue is you are using a face hosted instead of ceiling hosted.
Nachricht 9 von 10
Mike.FORM
Nest that family and load it into a new ceiling based fixture family and place it on the ceiling in the family.
Nachricht 10 von 10
Just select the solid host in your family and change the extrusion thickness to 0 and it will be deleted. Then you can have the Always vertical box to check.  You also need to check work plane box and host the light onto a ref plane in the project.  If you don't check the work plane the light maybe upside down and you won't be able to flip it.
If the set height is from the floor then it is better modeled as a level based family with an instance parameter to extend the hanger up to the ceiling on a case by case basis.
