Handrail on wrong stringer
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
mdahlhausen
290 Aufrufe, 1 Antwort
Good afternoon, I have a staircase where the top flight oversails the bottom flight. When I try to draw a handrail and host to the stair, it will always follow the lower stringer for the level. How can I host it to the top one, or do I have to split the stairs to achieve this? Thanks
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: mdahlhausen
Unfortunately when you create new railing and host on stair, it will always host at the bottom. So your option is to create one stair with automatic railing attached or you split the stair into two parts so the railing will host properly.
