Hi all,
The handrail is missing in plan view but actually it is under the cutplane. and the same family is visible in plan view it is also under the cutplane. And there is nothing about workset visibilty or vg settings.. unhide the element also greyed out. could not find anyway to solve it. thank you
The only think that i could look is that maybe you move or create in diferente phase, check with filter phase none, if not maybe you need to look well its properties and tried to replied all the properties relates with visibility and graphics equals to another rail that you already can see in your plan view.
Your screenshot looks like an RCP View. If so, RCP view ranges are backwards from Plan view ranges.
