Handrail connection
2 ANTWORTEN 2
Nachricht 1 von 3
PAarchitects
150 Aufrufe, 2 Antworten
Handrail connection
How can I move the extension post @ both ends to the same height as the railing?
attached rtv of the stair (revit 2022)
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: PAarchitects
I notice the start & end post will always set below the railing. Even if you set the baluster height as 3', the start and end post will always cut off based on the railing diameter. So you have to add additional parameter to allow offsetting for the start & end post
Nachricht 3 von 3
