The railing's path sketch needs to be on the stair to be hosted. If you need to move the railing closer or further from the wall then use the offset values provided for the rails/baluster/supports etc.
Steve Stafford
Press the "Flip Railing Direction" Flipper.
...and/or maybe change handrail Position?
Hi @Fa19-cve-051
Thanks a lot for posting your question to the forums! Have the solutions suggested by @SteveKStafford @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
