Halftone creates different color between filled region and model fill
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ThijsLugt
2018 Aufrufe, 5 Antworten
(see attachment )
We have some groups with a filled region, that we paste on wall/floor/foundation (intersection) to add some small details.
In a later stage it is sometimes needed that we halftone the entire section, because we want to draw the attention to specific parts (those are not halftone) and that works pretty good.
The problem is that halftone creates a difference between filled regions and material color even when color settings are the same.
We dont want to change the filled region color in halftone situations, because that will also change the detail groups in non halftone.
How do we get this to match, and why does halftone create differences in the first place.
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
martijn_pater
als Antwort auf: ThijsLugt
Perhaps you have some double halftoning going on... like override in view halftoned + overwritten model category halftoned, or a view filter... maybe zip/share (part of) the file to have a look.
Nachricht 3 von 6
ThijsLugt
als Antwort auf: martijn_pater
I couldn't find any other overwrites in the project.
To be sure i started a new project without a template and i had the same result.
You can find a screenshot of the outcome and that revit file in the attachment.
Nachricht 4 von 6
martijn_pater
Set the solid fills as background, not as foreground. Not sure why it matters actually, but this should resolve the issue.
Nachricht 5 von 6
ThijsLugt
Thanks, that the problem..
Nachricht 6 von 6
curtisridenour
thank you. this was exactly my issue as well.
