Hello people i was wondering if anyone had a half-tie roof trusse i've looked in the typical websites but i can only find the normal type. Many thanks ( I posted this on structure side but no replies)
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
hello @roscopeco2000
Half-tie isn't a conventional name which we use for a truss over here. So it would be better if you provide some sketch in order help us help you
Its this shape its for high ceilings i cant seem to modify the existing ones so the horizontal beam can go higher..
You can open the W or the Fink Truss from the Revit library and modify it to this shape...it is not far off from this one...However; in the Family Editor you need to go to Visibility Graphics >> Annotations Elements and check the box to show them so you'd be able to unlock the constrains and set the elements as per your sketch.
If you do not need it to function as a Truss ... could also model it as a generic family from scratch
Probably another stupid question but do i need to do anything with this or just add in as i normally would as a family part? it keeps coming up cant create this kind of element in current mode.
He took the truss family and amended...which I assumed you could do. If you are a structural engineer and as this is a structural element, you should flex it, change its members, check its structural integrity if it functions the way u need it to, add steel connections to it...etc. It's a parametric structural element ... that's what one usually does.
if you are not a structural engineer then as said before you most probably need a family, modeled in a Generic template and which represents the so looking half tie truss. and not the structural one....In other words if you are not running analysis, that's not your family!!
You do do realize that you can build that using wooden beems straight in the project too?
i didn't mate i have been using so the software 4 weeks, i try and learn using google/forums in evening. I come from using Inventor/Autocad so i have some experience of parametric modelling its just relearning how to do things again..thanks for advice
Then you will need to start with simple beam in the project environment and slowly move on to families... something similar to the below
