Guardrails
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
lorissa
249 Aufrufe, 2 Antworten
Guardrails
The top rail of my guardrail is not aligned with the posts.  I can't seem to find the setting to center the top rail over the posts.  Should be simple, but am at a loss.  The balusters are all centered, but not the end/corner posts.  Any thoughts?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: lorissa
Edit Top Rail type and change Hand Clearance parameter.  The value depends on the Width of the Top Rail profile and how it is drawn.  Example below for the 2" wide OOTB top rail.
Nachricht 3 von 3
lorissa
als Antwort auf: ToanDN
That solved it!  Thanks!
