Groups Are Differing in Revit 2018
4 ANTWORTEN 4
Nachricht 1 von 5
Hugh_Compton
583 Aufrufe, 4 Antworten
I have attached a Revit 2018 format file.  In it I have attempted to cut holes in a group.  The holes will cut BUT only in one Group.  Any other copies of this Group are not being updated.
It doesn't make a difference if the elements doing the cutting are in the Group or not.
This used to work in Revit 2017....is this a bug or have I done something wrong?
Thanx
4 ANTWORTEN 4
Nachricht 2 von 5
Hugh_Compton
als Antwort auf: Hugh_Compton
I have made a screencast showing the BUG!
Another thing is that when i remove an element from a group the removed element appears in every Group location.  This isn't right, it should only appear in one location on the Group being edited.
Nachricht 3 von 5
I tried joining/cutting geometry in groups with a simple in-place model and I can't get it to work in 2018...or 2017. Are we sure this isn't typical behaviour?
Nachricht 4 von 5
FGPerraudin
Hi @Hugh_Compton,
Actually in your case, the voids should be part of your Revit Family, and then you wouldn't have any trouble!
You can the use a parameter to make these voids cut your geometry or not.
Basically Revit is having a confusion between your group and your family.
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 5 von 5
Hugh_Compton
als Antwort auf: FGPerraudin
I would just like to add that this bug still exists in Revit 2025.
One workaround that I have found is to use the Group Links.  This creates a separate RVT of just the group elements that are linked to the original Group.  Adding a hole in the new RVT and then updating the links makes all of the Groups update with the hole.
It would still be better if the Revit team could fix this bug so that we don't need to work with linked files in this manner.
