Groupin area calculations according to each appartment on the same floor
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
374 Aufrufe, 2 Antworten
I have a multi-storey building with 9 appartments on each floor.
How can I generate an areas schedule, which sums the total area for each individual apartment?
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: Anonymous
You can add a parameter as text called "UNIT Type". Then select those area and add text to them calling "SUITE A", "SUITE B" and etc. In Schedule, you would add UNIT type to the schedule and use that as your Sorting parameter. This will group those area together and you can calculate total on the unit.
Nachricht 3 von 3
martijn_pater
als Antwort auf: syman2000
What @syman2000 said. In addition what he means is a project instance parameter in the area category (manage tab) and while sorting you can add a blank line for instance and/or header/footer totals calculations for the sorting parameter etc. fwiw: if you want to sort by level aswell you could do this by adding it to the schedule to sort by also.
