In my working revit file I assigned wall workset for wall element & window workset for window element but after selecting these and creating group , Group takes control active workset [Eg:workset 1], Even after ungrouping the elements doesn't reswitch to assigned worksets. Why Group workset takes whole element control? Is there any other solution to assign worksets for elements as it is even after grouping?
Groups and families have a Type Workset and an Instance Workset that do not have to be the same.
All elements in a group are in the group instance workset.
To edit the group, make the group type workset editable or borrow the group type.
To modify the elements inside a group, make the group instance workset editable.
To determine the worksets in which the elements reside, select elements and check the Workset property on the Properties palette. If you use element borrowing to check out a group instance, Revit automatically borrows all elements in the group.
