Hello Everyone,
I have a weird problem in my model.
This is a subtracted pice of my model:
Parts of two houses with the same floor plan solution. This is only one single group that has been copied.
This is said floor plan:
Now there is a new problem that has occured out of nowhere... When I try to do some stuff in the modell for example adding walls, adding areas etc. this dialog shows up:
What does this mean and why has it syddenly started to show up? I do not want to break my groups which I am suggested when i click fix groups.
Any help is appreciated. File is attached.
Thank you!
Gelöst! Gehe zur Lösung
Ok, this got solved... sort of. The different groups were slightly of axis.. an angle of 0.001 degrees. This messed everything up. I deleted all groups except one and made sure everything was straight and then placed them again. Now it works!
