Is there a way to show a color scheme in a gross area plan based on occupancy type?
when I add a color scheme legend, it only shows the category Areas (Gross Building). is there a way to show spaces color schemes?
Add a Project Parameter for Occupancy by Area and assign it to Area Category. It will be available to Color Scheme.
should have clarified something, trying to show spaces or hvac zones color legend to the gross area plan.
already using the areas for the gross area calcs.
that's what i'm trying now but in revit, overlaying the color scheme plan over the gross area plan, you can see through the color scheme but when printing the color scheme is not transparent. when I change the view to transparent, the colors disappear.
- Set the color scheme to background
- Place the Flor Plan first, then the Area plan on top
OK. what about the floor slabs?
*edit* will try to set the bottom of the view to -1" below the slab and change the view template floor slab to 100% transparency
