Gross area plan needs fix, have never seen a error like this! plz help.
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
463 Aufrufe, 6 Antworten
Hey there, i usually find the solution to my problems on the forums here but this one i cant seem to find anything on. i work for a company where we just had our hole building portfolio digitalised, and then i find out, that in one of the files there are missing a gross area plan, so i make one, and this is what i get (see picture below) i cant zoom or do anything else, the only thing i can see is the line i marked and as u can see it is very long tho the building is only 9000x7000mm, so it dosnt rly make sense..
i am going crazy :Gesicht_mit_Zunge: and i think i have tryed everything
can anyone try to help me ?
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
try to pick into your screen then go to properties and untick crop region and check also your view template if any assigned to that view and  see if helps. thanks
Nachricht 3 von 7
als Antwort auf: ennujozlagam
didnt help. now i see every where i click in the view i toggle this area boundary line thats very short, but i cant see it, and i can toggle it every where in the view.. its so strange. :verwirrtes_Gesicht: 2019-05-29 09_09_24-.png
Nachricht 4 von 7
ennujozlagam
anyway you can share the file so we can check. thanks
Nachricht 5 von 7
Here it is :leicht_lächelndes_Gesicht: its the "Floor plan: 1000 Villa" that i have troubles with when i try and make a gross area plan. it can make the gross area plan, but its totally ****ed, as i explained.
Nachricht 6 von 7
ennujozlagam
It's already fixed caused of the problem - area boundary not on the work plane. thanks
caused 1
caused 2
fixed
Nachricht 7 von 7
Thanks alot!!!! :leicht_lächelndes_Gesicht:
