Hi all,
How can i display grids in 3D view?
I have tried to turn on the proper grids box in visual graphic but it seems not working properly.
Grids do not display in 3D, yet.
Revit doesn't do this yet, only 3D levels. See link below for a work-around.
https://forums.autodesk.com/t5/revit-architecture-forum/3d-grids/td-p/7380456
What are you trying to accomplish by seeing the grids in a 3D view?
It's probably because ArchiCAD does it. I remember when AC first showed levels in 3D, then grids showed as well. Couple of years later Revit showed the levels in 3D....so eventually we will get 3D grids too.
Hi.
To have an overview of structural model, especially when it has to be imported in Robot.
I think it could be nice to have the same function in Revit too.
I could understand wanting to be able to control the 3D extents of the grids in a 3D view but seeing the annotation linework, I don't get. I think the levels look silly in 3D but having the control of the 3D extents of levels in a 3D view can be quite useful.
