Gridlines not displaying on Basement Plan
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
tstewart
895 Aufrufe, 5 Antworten
The upper floors display grid/column lines, while the Basement plan does not. How to display the column grid on the Basement plan, so that it matches the upper floors?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: tstewart
Raise/Lower the Grids in Elevation View then.
...enough so that they intersect the cut plane of the View you can't see them in.
Nachricht 3 von 6
Their 3d extent are above the basement level.
- open a section and drag the grid 3d extent grip (blue circle with a 3d text next to it) down to below the basement level
- or an extreme approach: select a grid in any view > right click > select all in project > right click > maximize 3d extent
Nachricht 4 von 6
tstewart
als Antwort auf: ToanDN
Thank you.
Nachricht 5 von 6
tstewart
Thank you.
Nachricht 6 von 6
@tstewart wrote:
Thank you.
You're welcome, Thaddeus.
