grid
grid
76jsa
grid
76jsa
I have a grid.
All the grid lines I can see only in 1.floor and above.
Only some of those grid lines I can see in -1.floor - the grid lines are originally placed in -1.floor.
I need to see them all in -1.floor, any help?
jeroen_vanmassenhove
Go to a section view or an elevation view. You'll see the gridlines and you need to make sure they extend to the levels where you need to see them in plan view. Just pull the end of one grid line and the rest should follow.
dferreira-blackwell
If Hidden:   Are they just hidden? try Revel Hidden Elements ( Bulb Icon ) at the bottom of the screen. press it to find grids, select them, right click and press unhide.
If extent issue: create a section view which cut through all grid lines. open the view. find the grid line which is not passing through level datum. unpin them if pinned. drag them below level 1 datum. it will show.
