Grid
Grid
Grid
I created a grid in one level. i do not see it in other views.
is it possible to view it?
Thanks.
arunag
You can do one of this:
1. Select the Grids ... Right click...Maximize 3D extents
OR
2. Go to the elevation & manually pull up the Grid to the Levels you want it to appear.
The former is quicker.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Could be something obvious like the grids are not set to dipsplay on the other layers - check the Visibility Grpahics (shortcut VG), and check under annotations (I think).
More likely, it is that the extents of the grids do not extend to the other levels. It is best to think of grids in 3d, with each gridline as a plane.
Check the section or elevation view, make sure that the gridlines extend upwards to include all building levels.
I did it in section view.
Thanks.
