Hi guys, does anyone know why i cannot see my instance parameter in this grid head? it only appears when i select the grid, otherwise i see the ? sign. Si in theory the instance parameter i have of the grid type works, but only when i select the grid, and i need to see it in the drawings.
Gelöst! Gehe zur Lösung
Gelöst von lm4. Gehe zur Lösung
It looks like the Grid has been edited dies it make a difference if you change the Annotation Symbol? Or transfer one from a new project using Transfer Project Standards?
thanks for the reply, i have found that the grid type was a multi-segmented grid, not a simple grid, and that was the issue, i have just made simple regular grids and then everything worked.
