I need to export/import a lot of .ifc files to be used with cadwork software, and I cannot get my levels and gridlines to export to .ifc and show up in cadwork.
- I have checked my .ifc settings. grids are set to export as ifcgrids.
- I have tried exporting with export 2d plan view elements checked, as well as export only element visible in view, and both on at the same time. Nothing yielded any results.
- grids and levels are both visible from the 3d view I'm exporting from.
Any other ideas?
Gelöst! Gehe zur Lösung
Gelöst von NathanMorassut. Gehe zur Lösung
Can you share the Rvt project? Also, check if atleast one Level is set to Building Story.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Louis
Please mention Revit version, especially when uploading Revit files.
I ended up talking with the software company and it's not something their software support right now, but they are working on developping
