I have a problem when I change the name of the grid line it disappear from the plan but it is showing in the elevations and sections
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Could you share more details? Revit version or anything that may be relevant.
Could it be a filter in your view or view template?
To check that create a brand new floor plan on the same level and see if you still get the same error. The new view should reset all the VG stuff. 90% of quirky issues like that get solved when I create new views.
HTH!
You say: "when I open the ground floor plan there is grid G when I change it into C it disappears from plans but it shows in elevations and sections"
I am surprised Revit didn't throw an error on you. You can't change G to C because you already have a C, and that's what you are seeing in Elevation/Section. You are seeing the existing Grid C .
Open your "ELEVATION 03" and Reveal Hidden Elements. You'll immediately see the Grid G displayed in the View just to to the left of your Grid C.
yes I know that because GRID C is not appearing in my plans but it is only appearing in sections and elevations,
try to delete grid G and solve my problem to show grid C in plans
This Filter is acting on the Ground Floor View. Remove the Filter from Ground Floor View and Grid C will be visible.
