Grid line command is not showing navigation lines or reference line of the center of the wall as i hover over the walls in drawing, why ?
3 ANTWORTEN 3
Nachricht 1 von 4
ppatil026
223 Aufrufe, 3 Antworten
3 ANTWORTEN 3
Nachricht 2 von 4
EATREVITPOOPCAD
als Antwort auf: ppatil026
While using grid line command, hover over wall, hit tab few times until you get to center of wall
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 4
ppatil026
als Antwort auf: EATREVITPOOPCAD
already tried,but not happening
Nachricht 4 von 4
Maybe your Snaps are turned off.  Have you checked?  You can also right-click when placing Grid and then select Snap Overrides in the drop-down menu.
