I am trying to work out a pattern for green roof in Fill Pattern. I created it by using PyRevit. But when I created the filled region or add pattern to surface of an element (Roof) . It is coming out blank. I tried to override the graphics view of the element but nothing is happening. See images attached. The pattern is about 100mm tall.
Any suggestion would be greatly appreciated
Could you maybe upload the .pat file so I can test it? might just be a scale issue?
Out of interest is it a drafting or model pattern?
Does it display in 3D? If it does but not in your plan then it could be a visibility issue?
Are the Roof Projection Lines turned on in the View? What color are they? 255-255-255?
Hello
I did more investigation. I created a new project and the pattern and filled region are grand so when I copied it to the existing project (not before I deleted the roof types and purge used)..............The 2nd image tell me that I am losing the pattern and it is making it gray......???
Also none of the pattern/filled region such as Diagonal Crosshatch are showing too. Does this mean that the model is corrupted?
Hello
