I was running GBS and the simulation takes ages...the status stops at "In run queue" and never finish it.
But I have successfully simulated the same case before.
Any suggestions?
Hey endison,
Discard your present simulation. And in Revit in Energy setting Dialog Box increase the value of Analytical Surface/Space Resolution by 5-6 times . Now again with your current settings run your simulation . I hope your analysis will be completed soon.
Nitesh Saluja
hi @Anonymous I just tried your solution and It works but now the calculated area is lesser than before. The EUI is similar but with a 5 times smaller area.
