When I go to ‘modify sub-elements, some of the grip boxes are blue, and some are green. What’s the difference? The blue one in the center in the example below is hard to select.
Solved by ToanDN. Go to Solution.
- The green dashed lines are the boundary lines
- The green dots are the boundary vertices
- The blue lines (not shown in your picture) are split lines added via Edit Sub elements
- The blue dots are points added via Edit Sub elements
During edit Sub elements, you can select any of the entities list above and type in the elevation value to change it.
