Greating appearance of double stud
2 ANTWORTEN 2
Nachricht 1 von 3
cadpro78
201 Aufrufe, 2 Antworten
Good day; I'm trying to figure out how to make a DS with a curtain wall panel from the storefront. Right now, all I have is single studs, which is fine, but at the ends of the wall should be DS for bearing support of headers.
Essentially I want to copy the stud (mullion).
Can this be done?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: cadpro78
Add another Grid Line/Mullion next to it.
https://www.youtube.com/watch?v=pyPOnxIMgg8
Nachricht 3 von 3
....actually, based on what I'm seeing in that Elevation screenshot, it almost looks like you want this:
Beam = Structural Framing of the size/shape as CW Mullions.  Or use a Column that is the size/shape of the CW Mullions.
