Grayed Out Graphics
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
DavidRaines
5706 Aufrufe, 2 Antworten
Grayed Out Graphics
I am operating windows 10, Revit 2018. Autodesk Architecture.  The graphics overrides on the properties menu is grayed out. How did it get there and how do I change it?
David
2 ANTWORTEN 2
Nachricht 2 von 3
amorap
als Antwort auf: DavidRaines
Hi David
Check it there are applied any view template in the view propoerties palette.
If you apply a view template from the properties palette, then the visibility  graphics override are grayed out.
Regards
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Nachricht 3 von 3
DavidRaines
als Antwort auf: amorap
Thank You for your response. Amazingly it corrected itself while I was engrossed in following your suggestion.
David Raines Architect
Wave Design
