Graphics Glitch
2 ANTWORTEN 2
Nachricht 1 von 3
ruiz
307 Aufrufe, 2 Antworten
Graphics Glitch
Hello all, I am encountering a problem with Revit 2018.2 where the cursor gets stuck in processing a command and doesn't change at all. I typically have two sheets open in restored down windows, when I attempt to move one by the title bar the mouse turns from the white arrow icon to the blue spinning wheel. This goes back and forth endlessly (from white arrow to wheel) and the only solution that seems to work is closing the program via the task manager window.  Is there a setting I need to turn on or off? I have "hardware acceleration" turned off for now, although I have had it turned on in the past and still have the same issue. By the way, I am on a brand new HP workstation. Thanks for the help.
2 ANTWORTEN 2
Nachricht 2 von 3
Luiscko
als Antwort auf: ruiz
I think the better way to solve this problem is update your versión with the fix up , maybe if you install this update your problem.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Nachricht 3 von 3
ruiz
als Antwort auf: Luiscko
Thanks Luiscko, will try!
